Rizz
Punto Mk1 1242 8 valve 1998
One of the rear drums is binding. Before doing anything I loosened the hand brake adjuster inside the car. The drum was turning freely before I took it off to check the shoes. I did have to use a lot of hammering and levering to get it off.
When the drum was finally off I made sure the adjuster on the shoe was backed off so the shoes sit as far into the wheel cylinder as possible.
BTW the shoes are not very worn though drums will need replacing next time. I filed down the lip on drum edge.
Now I can push the drum on all the way and turn it ok. BUT, when I screw in the locator pins the binding starts. When the road wheel is on with all bolts tight then it is binding big time.
Anyone know what is happening? Maybe I’ve b******d the back plate Thanks for any info as I’m now clueless with it.
