Old 01-04-2011   #1
Ireland
Service due
Service is due on my mk1 punto 60s
Basically i want to do an extensive as possible service as i dont know what the car has had done before.
What would you guys suggest i.e. oil type etc etc. the plugs , timing belt, and head gasket have been replaced and flushed coolant system.
so is it just an oil change?
Also does anyone know what the grey button beside the passenger seat is for. it has a petrol pump with an line through it.
MArtin
Martron is offline Reply With Quote Quote
Old 01-04-2011   #2
Re: Service due
Do a search, there are threads that are on going at the moment with all the information that you need.
The grey button is your fuel cut off switch by the way.
Thanks Martron thanked for this post
jimboy is online now Reply With Quote Quote
Old 01-04-2011   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Service due
60s is an 8v IIRC
eitherway
What milage you at? - a good start
But Filters and Oil + Coolant Change is always a good thing todo regulary
But Stuff like Thermostate - Belt - Pump - Tensioner stuff like that are done at certain points in its life
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 01-04-2011   #4
multiplied has donated!
Re: Service due
hi, i have carried out my own car services for over 20 years. on a petrol its the right grade of quality oil, usualy a good semi-synthetic is more than adequate unless you drive a sports car. i use valvoline myself, new oil filter every change, air filter every 2 years, pollen filter every 12 months if fitted, spark plugs (but you say they been done), i also fit new bosch wiper blades every year. if you go to a car factors ( i use autoparts), cost on a full service is around 50 for parts). other than that i wd40 door locks & rub on some castrol clear grease onto all door & boot hinges.
check all fluid levels & top uo screen wash.....& your good to go!
multiplied is offline Reply With Quote Quote
Old 01-04-2011   #5
Burkina Faso (Upper Volta)
Re: Service due
Quote Originally Posted by jimboy View Post
only goes off usually if car gone over a major speed bump or hit a wall,dont worry about it
with regards servicing if major parts on engine already done like plugs then an oil and filter will give it the elixior of life for another year
s and b is offline Reply With Quote Quote
Old 01-04-2011   #6
Ireland
Re: Service due
thanks for all the replies.
the car is 1998 has 60k miles.
i recently replaced the head gasket and with the all the belts and tensioner. ( i over looked the water pump when doing this but the timing belt was done at 48k and there was a water pump put in then. ) and the plugs and the thermostat.
was wondering if there was anything else i could have a look at seeing that i was going at it.
( in case anyone is wondering the timing belt was replaced with the head , the car is a real frankenstein bodge job. there is nothing in the car that was not interfered with .and the timing belt and head was replaced at 48k. who ever replaced the head over tightened the rocker cover and pinched the seal andoil has been seaping out all over the belts. the rocker i found later was twisted due to overtightening. and the belts were ruined. )
Old 01-04-2011   #7
Re: Service due
Rocker cover gaskets leak if re-used so the less educated pull them up tighter and make matters worse. But new covers and gaskets are not costly.
DaveMcT is offline Reply With Quote Quote
Old 01-04-2011   #8
Ireland
Re: Service due
i did not reuse the gasket i replaced it when i replaced the head.
it leaks a small bit but not as much as before.
Old 01-04-2011   #9
Re: Service due
Oil change,
Air filter,(get a K&N panel filter)
Plugs (they are cheap enough)
Strip+clean+copper grease front brakes (caliper slider's seize all the time) Replace as necessary,
Strip and check rear brakes+adjust hand brake,
Check brake fluid condition (colour) If dark give give it a good bleed and flush though.
Grease the end if the clutch fork arm.
Possibly check ignition timing, if you can on them Punto's, i don't know
Because learning is fun
GrandeGuy is offline Reply With Quote Quote
Old 02-04-2011   #10
Re: Service due
If the rocker cover leaks try some Loctite 518 or similar but if that's no good it probably needs a new cover.
(G) Service Due Message? chriscboy Stilo 4 04-04-2010 11:10
(G) Service due soon BRAV-OH!! Bravo 17 06-11-2008 23:45
(T) Im due a service in 2k Mattyk Grande Punto 3 27-08-2008 10:23
(G) service due! t-jetfc Grande Punto 9 13-08-2008 22:45
Service Due hughesmutu Garages 2 04-05-2008 13:30
