After months of having my Punto sat on the drive doing nothing, I finally got around to starting the engine swap yesterday.
The original problem was that is was consuming oil rapidly and emitting horrid blue smoke when accelerating (when warm); the pistons and bores looked terrible so I opted for a new block. I got a 66Ker off eBay for £110 delivered, but this was sans gearbox and ancillaries.
I decided to take the bumper off to get the necessary clearance, I wasn't really happy with jacking the car up any higher (note the gravel driveway!). In the end it made it way easier to get to things.
Loads of space now!
Took the opportunity to change the old clutch and bearing. Friction plate had about 1mm of material either side left.
Outstanding issues
New engine is non-power steering; crank pulley is different and crank sensor hole is in the wrong place!? Do I have to swap the whole crank end-plate to get around this?
Nearside lower suspension strut bolt is seized into the swivel hub assembly, any suggestions on how to get it out? I sheared the nut off try to turn it, on the other end it rotates freely so I could swing the hub outward to get the driveshaft out of the gearbox but it is not budging.
Loads of space now!
Outstanding issues
