Technical Cambelt Change
Heather123
I know Fiat recommend changing this on 72,000 miles (i think) or every 5 years. My Punto is just on 5 years old (going by date of registration) and as far as I know the belt hasn't been changed - can't see a reason why it should have been, however the car has only done just on 7000 miles. Is it best to change is this year or maybe wait a year or two more?
Also, is such low mileage on a 5 year old car a bad thing? It was only 4000 miles when I got it, I'm trying to build up the mileage a bit whilst the petrols cheaper :-D
i have a 60,000 mile punto which is 8 yrs old and not done it. Tho i am going to have it done in the next few weeks.
I would have it done, not at fiat but at a independant garage.
i have had a quote for £45 for a cambelt kit and £40 to fit.
Is it a 16v or 8v engine?
personally i'd get the cambelt changed (i had mine changed at around 32k/5yrs) lack of use is just as bad as over use especialy with rubber as it can crack
the only think to look for on low mileage cars is if its on the original tyres the rubber will have degraded although they have plenty of wear left and the exhaust will rust as it will not have been very hot for long period to remove water condensation
Thanks for that - my MOT's due end of January so if it passes I'll prob get this done straight away. £85 doesn't sound bad though, i thought the cambelt change was about £200-£300!!! - but then, I don't know much about cars!
i think if you went fiat you would be looking at £300 plus.
I had a price for £183 at national autocare ( which is part of AA ) there nationwide. if you want to just drop off.
If you having the mot at the end of the month they will do that for you, service and do cambelt. prob get it back same day.
j
it is for us jtd owners, £240 for cambelt and alternator belt at an independant garage
dont worry about it if its an 8v engine.
if that belt was to split it would not cause any damage.
I would defo leave it, as if it was to snap. i could get me girlfriend to do it!
and she has never used a screwdriver !
lol
Heather please dont waste your money!
Oooh thanks, that's good news. I'll always buy an 8v engine then methinks :p Thanks for your answers!
Heather, change the belt and tensioner at your next service (12,000m?). Don't let it run till it snaps, because (you know it!) it'll be in the middle of nowhere, on a dark and freezing cold night while you're taking your cat to the vet for emergency surgery or something... You don't need THAT grief.
And you'll have to pay someone £200 to tow the beast home.
... the car, not the sick cat :D
Ralf S.
personaly id follow what the book says. even if you aint done many miles, but its had a few years on it, if the book says to do it then do it.better to be safe than sorry.
my car has only done 26k and its a 53 plate.low miles but i dont do many miles which dont do it too good neither.but as its 5 years old now il change it. if you follow the fiat books, your car will last much much longer.even if it means spending the money now, youl know that your car shoudnlt let you down:)
are you mad? books go out of date
should go by latest info out
There seems to be a lot of confusion about when the timing belt is due for a change.
In a lot of service manuals and owners handbooks are intavals quoted of up to 80,000 miles and up to 10 years. This might have been the general consensus at the time being an we are not disputing this at all.
The largerst timing belt provider to automotive industries (at time of writing) is Dayco. Dayco supplies timing belts to the production line as well as to all after market suppliers.
Dayco has revised the timing belt changing intervals to 36,000 or 3 (three) years. This is due to the fact that the belt failure rate has increased in recent years dramatically over the three year period. This is not due to lower manufacturing quality. The stresses in the environment in more modern engines are much increased and therefore can't last as long as in comparatively less stressing conditions.
The fact that a lot of timing belts do not snap well above the three year period or the 36,000 should not lead to the conclusion that it is not necessary to change the belts earlier than the previously promoted recommendations.
Everyone be advised that the intervals set by Dayco are a safety recommendation to safeguard many engines that might suffer valve damage in case the timing belt brakes. But more importantly the manufacturer is also aware that a broken timing belt might bring the driver and other occupants of the car into life threatening danger, which might even extend to members of the public that are passers by.
It is therefore rather wise to change the timing belt at 36,000 or three years or if not known when it was done rather the earlier than later.
If anyone would like to argue about it with anyone here, just point to this thread.
