FIAT Auto Specialist Team
Thread Tools
Old 10-01-2008   #1
Ireland
What's wrong with my car??? Help!!!
Hi guys,
I have a 1997 Punto 1.2, SX60.
The past couple of days the car's gears have felt a bit weird. The engine would be loud in 2nd gear so I would go up into 3rd and the car would kinda slow down! And the engine would still be noisy. I would have to accelerate a lot. Now I didn't think too much of this because the route I take to work has a lot of upward slopes and I know if you go into a higher gear too early on a slope it makes things worse.
I should probably mention that I have a habit of staying in 2nd when I should be in 3rd, if I am going through 2 roundabouts that are say 300m apart I won't bother changing gears. Maybe this has damaged my car?
This morning the car cut out about 7 or 8 times. The traffic was mad and I was stuck on a steep hill for ages and the road was wet. I thought maybe it was my hill starts that were at fault and maybe ti was because the road was so wet. Then I was on the Belgard Rd which only has a very small slope, I rarely need do do a hill start. The car cut out another couple of times. Very frustrating!
I parked the car and when I came out on my lunch break and started reversing it out of the space I heard a squealing noise. Like the noise the kettle makes when it's boiled! I drive to Halfords, I'm going round the car park in 1st and the car is squealing. I move up to 2nd and soon it starts squealing again! I also had to accelerate more than I usually would need to.
I am raging, this is literally the first day this has happened but I am fuming, I don't have the car very long and I'm scared it will cost me a fortune to get fixed!!! What could be wrong??? There not too long ago the car used to make a noise when I accelerated which turned out to just be a couple of loose nuts on the wheel. I am hoping to god this is the same, just something small that is loose, but I am raging! I am also terrified the car will break down on me tonight on the way home, I wouldn't know what to do!!!
niamhh is offline Reply With Quote Quote
Old 10-01-2008   #2
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: What's wrong with my car??? Help!!!
Sounds like :-
1) Clutch is slipping.
2) generator drive belt is loose/slipping.
3) problem with ignition.
Not sounding cheap
Ffoxy is offline Reply With Quote Quote
Old 10-01-2008   #3
Bandido A Maneira!!
Trader Rating: 1
bandido41 has donated!
CTD High Jump Champion
South Africa
time for a new clutch kit if you are handy with a set of spanners, get yourself a haynes manual and you should be able to do it yourself.
All the arms we need are for hugging!
bandido41 is offline Reply With Quote Quote
Old 10-01-2008   #4
Ireland
the car has a new clutch already...
how much am i looking at to get the above problems fixed?
Old 10-01-2008   #5
andre88uk has donated!
The squeel deffo sounds like am belt mine used to do that til i revved it a bit... lol
PS cannot be held responsible for any damage casued by over-rev
andre88uk is offline Reply With Quote Quote
Old 10-01-2008   #6
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
This bit of your original post is classic clutch slip, if the driven and pressure plates were replaced with new ones there may be oil contamination from the gearbox/crankshaft seals.
Either way its a clutch job, generator belt and ignition work you wont see much if any change from maybe 200 - 300 if a garage does it for you. Much cheaper if a friend you know who can do it for you just gets the bits and works for cups of tea and sarnies.
Old 10-01-2008   #7
when you say car cut out ,did it literally stop dead or was it cutting out because you were in too high a gear for speed you were doing just to try and get rid of noise e.g. 20 mph in 5th
the sqealling could be the alternator (generator)belt slipping or could be tensioner , have you had timing belt changed recently. alternator belt is easy fix just a simple ajustment for someone who knows what they are doing,, similar for tensioner, although if its this you should replace timing belt at same time,,,,,its a little difficult to know sat here ,niether job should be expensive even for a garage although much cheaper if you know someone
when was clutch replaced? if new as you say wouldnt think this is problem
jaybee is offline Reply With Quote Quote
Old 10-01-2008   #8
Ireland
The timing belt was done and a whole new clutch fitted in the past year,
A friend of my boyfriend's is a mechanic, hopefully he will fix it for a bit less,
I bought the car privately from a mechanic who knows my mother but I don't want to go back to him again, maybe I should, one of the wheel nuts got loose and he came out and fixed it but I don't want to be bothering him again, his brother has died recently and I don't want to be annoying.
Old 10-01-2008   #9
Quote Originally Posted by niamhh View Post
I bought the car privately from a mechanic who knows my mother but ... his brother has died recently and I don't want to be annoying.
But you also bought the car in good faith and seeing as he is a mechanic why not just pay him a visit? explain the situation and maybe he will be able to fix it much easier than us lot can help you with.
His situation is a horrible one that happens to us all and im sure he is not going to hang up his spaner just yet.
Worst he can say is no after all ?
Old 10-01-2008   #10
Ireland
I would rather not, he didn't do a pre-MOT for another friend of mine.
Old 10-01-2008   #11
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi definately sounds like your clutch is slipping.(i know it was only fitted last year, but it could be for a number of reasons) The cutting out could be a number of things. If your not willing to take it back to the person you bought it from, then probably your next best bet is to take it to a local independant garage, or find somone who knows about cars and is willing to have a look at it for you.
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Thread Tools
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 23:20
Car sellers :( The Negotiator Leisure Lounge 57 15-01-2006 00:10
(G) What's wrong with your car? surfin_fella Cinquecento / Seicento 134 03-07-2005 14:51
