General Radiator Drain Tap
Hi guys. I need a drain tap for my 2012 1.4 Punto radiator. The original was white (ish) plastic. An alternative that fits is OK.
Thanks in advance.
Hi
Probably a standard metric thread..
So you could use a screw: bolt
Did you look at a direct replacement ?
Shop4parts can probably help there..
Or search yourself ;)
https://www.fiatdalys.lt/en/catalog/diagrams/104/6U/0/0/CC1.4/CMBBZ/GDX/cooling-system
Thanks. I already tried this, but no separate part is listed. Used parts vendors on ebay don't want to sell the tap separately.
Hi
This is a screenshot of one on ebay. 13mm wrench but 8mm screw too small diameter too small. I think it may be 10mm thread, but I'm afraid of damaging it and I only have a 10mm which is 90mm long. [emoji853] Screenshot_20210217_195919_com.ebay.mobile.jpeg
Is it not just the hose union..?
Compare the pitch ( coarseness .. distance between the peaks)
Of your m10 to the thread in thd rad body
Your m10 is 1.5mm pitch
M12 would be 1.75
If it looks a LOT coarser.. it could be 1/2 inch (12.7mm)
So a 1/4inch BSP pipe fitting from a plumbers could be what you need
Where are you based?
I travel the M4.. Charlie
