Old 4 Weeks Ago   #1
Headlights Always running when ignition on
Headlights are always running when ignition/key is on electric only is on same with interior dash and buttons - smaller lights interior and exterior flicker - stalk still has the 3 clicks and high beams work still. The ‘check running lights’ comes up but one of the DRL plugs fell out long ago but stopped working on there own before that.
Any thoughts?
I’ve checked the fuses 7.5 & 5 on exterior box and they’re good
JAM1905 is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
varesecrazy has donated!
Re: Headlights Always running when ignition on
Probably linked to your ABS error
Tell us more about your time with the car
We need to build a picture of what failed when.. after what work was done.. etc
Charlie
Old 4 Weeks Ago   #3
Quote Originally Posted by varesecrazy View Post
Charlie
Hi Charlie - my headlights where before my abs - first my DRLs went out and just never came back in and wouldn’t work - I always thought when my stalk lost control of my headlights it was after I went over a speed bump too hard. This was a good good while ago and I’ve just continued to be let down by people to look at it. My friend is pretty handy with his VW and has had a look at fuses etc - my smaller bulbs keep flickering when I unlock or leave the car as well. I’ve had it since 2017.
I have my ABS light on and the light bulb light on as well as headlights light on. The dash stays light when the key is in but all goes off when I take key out
Old 2 Weeks Ago   #4
This sounds like a problem I had.
Inside the indicator/light stalk are a red and black wire. One of these was snapped right at the bend.
To check for yourself, you can pry out the plastic part at the back of the stalk. This is non destructive and you should be able to put it back without too much of a problem but it is a little fiddly. Once inside, give each of the cables a gentle tug to see if they are loose.
If they are loose, you'll have to remove the airbag and the then open up the entire indicator stalk assembly to get good access to it. Instead of just soldering the broken cable back up, I created a bridge between the broken ends with a stronger cable as it would again be exposed to pinch point at the bend.
There's a really good video on YouTube for how to remove the indicator stalk (but it's in Italian so you might have to replay a few times to see what he's doing)
Likes jackwhoo, varesecrazy liked this post
Balak is offline Reply With Quote Quote
Old 2 Weeks Ago   #5
Good information for @JAM1905
Old 1 Week Ago   #6
Up to no good somewhere..
maggers's Avatar
maggers has donated!
It's worth knowing that if you change the stalks you have to tell the body module it's been changed. A strange one, it caught me out.
Likes varesecrazy, jackwhoo liked this post
Please note any offence caused is purely intentional
maggers is offline Reply With Quote Quote
(G) Post ignition rough running atom0007 Punto (Mk2/2b) 1 28-12-2015 10:44
(G) Headlights on - ignition off ! atomicwolf Punto (Mk2/2b) 6 20-01-2015 21:17
Engine still running after ignition turned off... richiejw76 Lets Talk FIAT 1 25-02-2011 11:15
(T) Engine running - ignition turned off! Tym Grande Punto 18 18-05-2009 15:41
(T) Cinq fan running when ignition off fingers99 Cinquecento / Seicento 9 23-09-2006 15:45
