Old 20-02-2013   #1
tessiedog has donated!
1.4 16v engine
Hi folks
Thinking of changing my 2004 Stilo Active 1.4 16v for a Grand Punto. For me one of the best things about the Stilo is the engine, which is fantastically revvy and to my mind delivers fantastic performance for the capacity (as well as really good fuel economy and a low insurance group). Anyway, point is - is the same engine used in any of the current range of Punto - have seen some advertised with the 1.4 motor, but don't seem to be the 16 valver?
Stuart
tessiedog is offline Reply With Quote Quote
Old 20-02-2013   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: 1.4 16v engine
Short answer - no. The 1.4 16v is used in the Abarth though I think.
Eklipze3k is offline Reply With Quote Quote
Old 20-02-2013   #3
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: 1.4 16v engine
It is used, but not in the same form, it's got a VVT setup.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 21-02-2013   #4
Re: 1.4 16v engine
The grande had the 1.4 8v (77PS), 1.4 16v (named Starjet @ ~95PS) and a 1.4 16v Turbo (Named T-Jet @ ~120PS)
scoop987 is offline Reply With Quote Quote
Old 21-02-2013   #5
Re: 1.4 16v engine
The 105 multiair is the same engine with a multiair system. If you like the 1.4 16v you will love the 105 multiair.
The sporting has the same multiair engine again with a turbo.
Driving: Alfa GT 3.2 V6 in black and Abarth 595 145bhp in Red.
Ransoman is offline Reply With Quote Quote
Old 21-02-2013   #6
Trader Rating: 2
Re: 1.4 16v engine
Quote Originally Posted by Ransoman View Post
What a multi air system
Old 21-02-2013   #7
Re: 1.4 16v engine
Its the fancy valve-train system that FIAT have developed for the intake valves. Its basically means that each cylinder's valve-train is controlled completely independent from each other. It uses solenoids, oil galleries that are controlled by the cam lobes (Basically just to tell the solenoid when to operate).
All thats good but also quite scary as when the engine is rev'd to 6000rpm, each solenoid (4 of) operate at 750 times a second. It also apparently reduces emissions but upto 15% and increases power by upto 10%
Old 21-02-2013   #8
Trader Rating: 2
Re: 1.4 16v engine
Quote Originally Posted by scoop987 View Post
Ah right, thats the one with VVT (Variable Valve Timing) then. I thought that was the starjet with VVT
Old 21-02-2013   #9
Re: 1.4 16v engine
Nope, The "Starjet" 1.4 16V has bog standard VVT where the camshaft turns based on oil pressure. The Multiair system is fiat's "next generation" VVT system. See:
Thanks Most Easterly Pandas thanked for this post
Old 22-02-2013   #10
Switzerland
Re: 1.4 16v engine
Multiair is far more than VVT.
VVT only allow to change valve opening timing. Multi air allow this, but can change open duration and even allow more than one open/close operation in intake cycle !
Multi air 16 V use 4 valve per cylinder but only on camshaft for exaust. Intake is managed by seleno´d and oil pressure.
A nice video :
http://youtu.be/3y0jIGq36Og
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 22-02-2013   #11
Re: 1.4 16v engine
Quote Originally Posted by Mkala View Post
A nice video :
But it still uses the exhaust cam on when to open by using some form of oil gallery valve so the solenoid knows when to open the valves.
(T) Stilo 1.4 16V engine in Punto mk1 1.2 16V 85bhp kimlong13 Cinquecento / Seicento 1 21-03-2012 20:57
(Tu) Stilo 1.4 16V engine in Punto mk1 1.2 16V 85bhp kimlong13 Punto (Mk1) 3 21-03-2012 20:01
(Tu) Stilo 1.4 16V engine in Punto mk1 1.2 16V 85bhp kimlong13 Punto (Mk1) 0 20-03-2012 22:23
(T) Punto engine swop - fitting mk2/3 16v into mk1 16v fostertom Punto (Mk1) 8 12-02-2011 22:05
