Comment
Guide Tools Search this Guide
MK2B STEREO WIRING HELP
s and b
30-12-2012
There is only one full time live in a mk2b punto at the stereo loom and its constantly live so even with key in your pocket its still pumping volts, ie your radio runs the risk of flattening the battery over a period of car non use or worse some car stereos get very hot if left with permanent live
Old 3 Weeks Ago   #15
varesecrazy has donated!
Re: MK2B STEREO WIRING HELP
That I believe is the standard ISO fit wiring
Coloured blocks might be for the CD changer under back seat.. or Amp -or Sub..in the boot
Old 3 Weeks Ago   #16
Thanks, I knew the iso, just didn't know the coloured blocks, even asked a guy at the fiat garage haha. Could it have had the speaker upgrade package at one time? I'll have a play on Wednesday when the speakers and stereo get here, paid more for that than the car.
ZOR is offline Reply With Quote Quote
Old 3 Weeks Ago   #17
There is 20 years worth of mk2 info on here
SEARCH is good.. you can specify which sections to look in
Old 4 Days Ago   #18
Can someone confirm if this is what I essentially have to do:
I locate the constant 12v power lead ( which i presume is the red and black wire, not sure if anyone else's is but previously when attempting to work on central locking I identified this red and black wire to be constantly live) which essentially, I should find the constant power lead where the cig lighter is?
and I expose the copper wiring and connect (solder) an additional wire to the yellow wire (whichever unswitched lead colour it is, which can someone just clarify what it's meant by unswitched aftermarket stereo lead? )
So to simple it down, find constant power, which is the cig lighter. Get extra wire (black as used above) connect said black wire from the constant 12v lighter wire to the yellow wire (which is the unswitched lead?
Also say if I'm trying to do it to a port like this
And the wiring they provide is this
Is everything described here still the same process? Except for I would need a cable like this right?
lowaaa is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Help with stereo wiring! tomfoster Stilo 4 28-01-2011 17:56
Help with Stereo wiring Matt76 I.C.E 3 31-10-2010 17:21
(T) Stereo wiring bluefozzy Punto (Mk2/2b) 5 10-09-2010 07:25
Stereo Wiring dj2020 I.C.E 2 24-06-2009 18:42
(G) stereo wiring etc d miller Panda (Classic) 2 04-01-2004 01:17
