hello!,
my car have the same problem, when try to start, the engine start and stop (cut off?!).
I check all fuses and relays, unmount relays for pump and injection, and put it unmounts to see if it works ok, and the relays are good and works OK!.
I check the fuel input, and fuel arrives ok to the inject rail.
I change the RPM/PMS Sensor, change sparks, check spark wires, and all its OK!.
I try to test the electical signal to the injectors, and arrives 11.4 volts when put contact, and when try to start the car, arrives only 8,9 volts to all injectors (I check all signals individually and arrives all 8,9v).
Fuel pumps its working ok, sparks ok, and fire its ok, relays and fuses ok... I try to insert manually fuel from air input to engine, and the car starts!!!!.
Can be all my injectors? into inject ramp (fuel comes to injectors) there is fuel, and I unmount any injector and fuel goes out.
I don't know whats happens!, my car is stupid!!!
If I insert manually fuel into air input, and the engine starts ok and don't stop (unless I stop insert manually fuel...), the problem is fuel do not enter into engine, but... if injector rail is filled of fuel, and injectors have electrical signal, I supousse the fuel must be enter into engine, but not enter.. I unmount injectors and mount it exit of engine, try to start the car and no fuel exit from injectors...
Can be injectors the cause of fuel don't enter into engine? can be the all injectors bad? how I can probe if the injectors are OK?
Thanks everybody!
Thanks everybody!
