DanH
- Apr 23, 2006
- 17
- 8
Coming home from Bluewater yesterday evening, I was sitting in traffic trying to get onto the A2; it was stop start so instead of wearing the nuts off the clutch I used the handbrake instead.
Anyway, after a while I could smell a horrible fishy smell and then burning, I ignored it as I thought it couldn't be mine as I was not riding the clutch and my car has only done 10k.
It got worse until the point where it was coming in through the vents and I had to give it 5k to pull away and it would violently shake so I pulled over into a entrance, switched it off it to let it cool down, tried it again, still slipping and now screeching.
Phoned AA, had to join up, £136.50 later, they said they were going to send someone, 2 hours later, I started the car to see if it would go, stuck it in 1st with the handbrake applied, found the bite point and it was not slipping, no noise nothing, so I phoned them, just as I did the bloke turned up and said it would be ok to drive, so I went, and all the way home it was fine.
3 questions;
# Why did it do this?
# Do I now need a new clutch?
# Anyone else had this problem?
Cheers,
Clutchfryingdan.
3 questions;
Cheers,
Clutchfryingdan.
