nawtwrong
I've just got hold of a 2nd hand standard punto sub that fits in the boot near the wheel arch. My problem is wiring it up. I have noticed that there is a small two-wire connector on the driver's side near the rear right speaker hole. I've connected this to a 12V bulb to see if it was for power and it is a constant 12V whether the head unit is on or not. I have a sub out on my head unit so I can connect the sub to this. Is it just a case of connecting the sub to this 12V supply and head unit? I don't want it to drain my battery when its not in use. Is there some way of doing this?
Any help on this much apreciated...
