Old 15-03-2006   #1
Cool BIG END Bearings - Easily repairable??! What are they?? please take a look
Hi guys,
Hope eveyone is ok on this lovely day
I've got a mk 1 sporting with what has been diagnosed as failed big-end bearings, which makes a loud rattle.
To replace these, as Haynes says, you need to take off the sump, remove the pistons, unscrew big end bearings and remove shells...etcetc..
However, to fix the problem what do I need to replace?? just the big end shells??
I also read somewhere that if the big end bearings are gone, then the main bearings will be gone also....
so if I do the work myself,firstly:
how hard is it?
What do i need to replace? both big end AND main bearing shells?? And if i do replace the shells, do i need to get the crank ground to match the shells?
I have done lots of work before on cars, but never really gone further down than the head gasket :P so all this bottom end of the engine needs understanding would be grateful if someone could explain what i need to do.#
Cheers Guys
dbriglee is offline Reply With Quote Quote
Old 15-03-2006   #2
Re: BIG END Bearings - Easily repairable??! What are they?? please take a look
If the big end bearings have actually gone then the crankshaft will have to be reground and new oversize big end, and main bearing shells will have to be fitted along with a set of gaskets.
Shunter is offline Reply With Quote Quote
Old 15-03-2006   #3
Burninator of threads!
faster4_tec's Avatar
faster4_tec has donated!
Mongolia
^^^^yeah that^^^
it is a fairly big job, the engine CAN remain in the car, but it depends how good you are at working upside down , crankshaft needs to be totally removed as do pistons to get the races ground ready for the new shells, cost me £35 for the grinding and polishing, once you have got everything prepped its pretty easy to put back, pistons all ways need to go back in same hole and exactly the same rotation (There are only two so not that hard, just careful prep work and well organised).
Its also a very very ver mucky job, as you get used black oil and gunk and dust off the floor all sticking to you in a disgusting mix of old oil and gunk, and you are bound to get some in your eye too
Volvo for Life
faster4_tec is offline Reply With Quote Quote
Old 15-03-2006   #4
HP
I was only doing 80...
HP's Avatar
HP has donated!
Easier to fit a new engine.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 15-03-2006   #5
midland fiat has donated!
how on earth can you remove a crank from a engine with it still in place????
midland fiat is offline Reply With Quote Quote
Old 15-03-2006   #6
Trader Rating: 10
dave has donated!
Quote Originally Posted by midland fiat
remove gearbox clutch, flywheel, put one of them bars that hold engine up in place, remove cam belt exhaust down pipe and sump, tis daft though, be easier to take lump out.
if it is bigends be easier to do what pete says change whole engine.
but it dont sound like big ends to me, they knock not rattle
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 15-03-2006   #7
only an idiot would do that tho, far more work! Not at all a sensible comment!
I have good engines for circa 200 if you find that route easier.
Old 15-03-2006   #8
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
When my parents tipo dumped ALL its oil and siezed, just replacing the shells from the bottom fixed it enough to run for quite a while after until the throttle pot broken (again) and it wasn't worth the nearly £300 cost for replacement.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 15-03-2006   #9
but an engine dumping its oil and siezing due to lack of lube will be in better state than a "worn" enigne, that will just kill the bearings and maybe just scratch the crank as apposed to wearing it out!
its still easier to swap engines with how cheap they are than messing with bearing swaps!
Old 15-03-2006   #10
Trader Rating: 10
dave has donated!
wtf you ask for if you didnt want the answer,
Old 15-03-2006   #11
no no no not aimed at you chill, no faster4tec, why suggest doing a crank job with the engine in place???
God dave chill
I just dont understand why on earth someone would tell someone to do such a major job in a mess about way, come on it makes no sense and helps no one!
Old 15-03-2006   #12
chill dave ive found the quote keys!!!!
Old 15-03-2006   #13
Trader Rating: 10
dave has donated!
he dont tell him to do it like that, hes trying to put him off doing it like saying about muck in eyes n its upside down job, its haynes that say its an in car job
Old 16-03-2006   #14
Mongolia
cos I did a crank job with the engine still in place, cos my wiring looms a mess, and I don't fancy having to chase up stupid electrical bullpop (mechanical problems = no problem, electrical problems = spawn of satan), but I found I needed a rebore and new pistons, so ended up pulling the block for a rebore and bigger pistons, my engines probably more like 1300cc now
Volvo for Life
Old 16-03-2006   #15
Exclamation Re: BIG END Bearings - Easily repairable??! What are they?? please take a look
[QUOTE=faster4_tec]^^^^yeah that^^^
it is a fairly big job, the engine CAN remain in the car, but it depends how good you are at working upside down , crankshaft needs to be totally removed as do pistons to get the races ground ready for the new shells, cost me £35 for the grinding and polishing, once you have got everything prepped its pretty easy to put back, pistons all ways need to go back in same hole and exactly the same rotation QUOTE]
cheers guys.
Id need to take the engine in to have the crank matched with the new shells wouldnt I??
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 23:20
Guide: How to wire an Amp Luke I.C.E 3 11-07-2005 19:33
(T) Big End probs?? monkertron Punto (Mk2/2b) 4 21-02-2005 09:43
