dbriglee
Hi guys,
Hope eveyone is ok on this lovely day
I've got a mk 1 sporting with what has been diagnosed as failed big-end bearings, which makes a loud rattle.
To replace these, as Haynes says, you need to take off the sump, remove the pistons, unscrew big end bearings and remove shells...etcetc..
However, to fix the problem what do I need to replace?? just the big end shells??
I also read somewhere that if the big end bearings are gone, then the main bearings will be gone also....
so if I do the work myself,firstly:
how hard is it?
What do i need to replace? both big end AND main bearing shells?? And if i do replace the shells, do i need to get the crank ground to match the shells?
I have done lots of work before on cars, but never really gone further down than the head gasket
so all this bottom end of the engine needs understanding
would be grateful if someone could explain what i need to do.#
Cheers Guys
how hard is it?
Cheers Guys
