Old 28-07-2021   #1
Punto handbrake
Hi
My daughters punto failed MOT handbrake not working pass side it works but I can just about turn the wheel with handbrake applied
Shoes look ok drums are ok Iíve changed the cable and auto adjuster
But I can just about move the wheel
Mr Posh is offline Reply With Quote Quote
Old 28-07-2021   #2
Re: Punto handbrake
Drivers side works fine Iíve noticed that the lever behind the brake shoe seem to be jamming on the hub not sure if itís worth changing the shoes or drum to get it through the MOT ?
Old 28-07-2021   #3
Re: Punto handbrake
Just had another look handlever moves as soon as you adjust the handbrake new auto adjuster but made no difference
Old 28-07-2021   #4
Re: Punto handbrake
Old 28-07-2021   #5
judderbar has donated!
Finland
Re: Punto handbrake
I probably made the mistake on my car of adjusting the handbrake to make the brakes have a harder feel while not realising it is normal for the brakes to have plenty of pedal travel with the engine off. And subsequently the handbrake never was any good. I then changed the original shoes after 250,000km and the difference was huge. With the handbrake fully backed off and feeling loose I still get a good solid handbrake in a few clicks.
I also got new adjusters but have never fitted them. I used a file on the original ones on the car so they lock on the ratchet better and touch wood that was one bit of fiddling that has worked so far.
judderbar is offline Reply With Quote Quote
Old 28-07-2021   #6
Re: Punto handbrake
Iíll change the shoes tomorrow see if that makes any difference Iíve checked the drum it looks like the original one so Iíll change that as well
Old 29-07-2021   #7
Re: Punto handbrake
Brake shoes changed I can just about move the wheel I'm not sure how good it has to be to pass MOT
Old 29-07-2021   #8
varesecrazy has donated!
Quote Originally Posted by Mr Posh View Post
Contamination should show in all brake operations.. not just the handbrake
There is an imbalance tolerance allowable for the footbrake..
Did you get figures?
Old 30-07-2021   #9
Re: Punto handbrake
No it just said handbrake inoperative near side
I beginning the think it may be the adjuster when the handbrake is off there is no drag on the brake drum
Old 30-07-2021   #10
Finland
Re: Punto handbrake
Have you checked the cables are working correctly? They should be totally freely sliding up and down when not connected so you can move the handbrake up and down from the drum end with no effort at all.
Thanks varesecrazy thanked for this post
Old 30-07-2021   #11
Quote Originally Posted by judderbar View Post
Post #1 says they have changed ' cable and auto adjuster'
Thinking nack to my sons Sei Sporting
We got ripped off.. £500 job on a £400 car..
But they said both wheel cylinders had 'damp seals'
So mew cylinders..shoes.. and bearings
It passed.. with a still not famtastic handbrake
Old 31-07-2021   #12
Re: Punto handbrake
Thanks for the help Iíll be back at it this afternoon
Iíll post some pics later
When Iíve refitted everything and pump the brake pedal there isnít any clicking
Old 31-07-2021   #13
Re: Punto handbrake
I have also noticed the isnít a return spring on the handbrake cable
But there isnít one on the other side and thatís works fine
Old 31-07-2021   #14
Finland
Re: Punto handbrake
When I’ve refitted everything and pump the brake pedal there isn’t any clicking
I think there should be some clicking but I dont think it will make the handbrake work any better. You will just need more handle travel to use the handbrake.
The MOT tester said handbrake inoperative. You have some handbrake now. It does not have to be perfect and it will likely bed in
Old 31-07-2021   #15
Re: Punto handbrake
The handbrake now works so I'll get it in for retest put the old adjuster back it after a clean up and it seems to have done the trick hopefully it will pass
Thanks for all the replys andvhelp I'll update after IRS been for MOT retest
Likes judderbar, varesecrazy liked this post
(T) Mk2 punto handbrake Flanspunto Punto (Mk2/2b) 27 10-04-2015 22:28
(T) List of fixes for useless handbrake, and best way to put handbrake on? Hipfidelity Cinquecento / Seicento 5 10-02-2012 19:07
(T) Punto handbrake Steve9258 Punto (Mk2/2b) 0 09-03-2011 19:46
(T) No handbrake warning lite when handbrake is applied. PUNKTO Punto (Mk2/2b) 8 18-05-2007 17:54
