![]() | #1 | ||
Posts: 19 Thanks: 0 Trader Rating: 0 ![]() | ![]() Noticed this a few times, however I thought I didn't put the nozzle in properly. I put the nozzle in and start filling up my car and notice that the nozzle keeps clicking to prevent me from filling up anymore. I assume somethings blocking it and causing the fuel to go back because it's stuck. Whenever I ignore the click of the nozzle and keep filling, I see that the fuel ends up building up and at that point starts leaking out. Once I stop I do see the fuel swirling down at a rather slow rate. Anyone got any ideas on what this might be? What's the fix like as well? Is it going to be a pain..? Thanks.
![]() | #2 | ||
Posts: 1,801 Trader Rating: 0 ![]() | Re: Fuel overfilling? It is a known problem on a Punto. Have you tried twisting the handle towards the front of the car so it pushes hard against the flap and then the handle begins to point upwards slightly? I got a low mileage fuel pipe and cap to see if it makes a difference and at the moment the problem is a as bad as ever! Some pumps are worse than others.
![]() | #3 | ||
Posts: 19 Thanks: 0 Trader Rating: 0 ![]() | Re: Fuel overfilling? It is a known problem on a Punto. Have you tried twisting the handle towards the front of the car so it pushes hard against the flap and then the handle begins to point upwards slightly? I got a low mileage fuel pipe and cap to see if it makes a difference and at the moment the problem is a as bad as ever! Some pumps are worse than others.
![]() | ahmett | 500 | 8 | 17-07-2017 14:08 |
![]() | wavestar | Punto (Mk2/2b) | 2 | 07-02-2010 14:44 |
![]() | larkim | Barchetta | 0 | 19-06-2006 10:13 |
OT overfilling the oil | Lee | FIAT Boo Archives | 1 | 17-04-2006 14:50 |
Overfilling oil | Anonymous | FIAT Boo Archives | 10 | 25-03-2005 19:25 |
