Old 11-09-2019   #1
Denmark
Dipped beam left side doesn't work
The dipped beam in the left side does not work. The bulb is okay and so is the fuse. I tried switching the fuses left/right with nothing changed. The upper beam works fine.
There is no voltage on the wire. If I remove the connector and attach an alligator clip to the plus pole of the battery, the lamp shines nicely.
So I guess the wire is broken somewhere along the way to the fusebox.
But how do I find the right wire in the mess of wires under the hood?!
marlar is offline Reply With Quote Quote
Old 11-09-2019   #2
judderbar has donated!
Finland
Re: Dipped beam left side doesn't work
Quote Originally Posted by marlar View Post
Just run a new wire from the head light relay to the bulb.
If you pull the relay out, one of the wider connections is always live. so you want to connect to the other side (of the two thicker contacts).
judderbar is offline Reply With Quote Quote
(T) Driver side dipped beam not working? benny279 Punto (Mk2/2b) 18 21-01-2013 18:12
(G) AAARGH!!! Headlights wont work on dipped beam and the cooling fan doesn't cut in!!! benjiman46 Cinquecento / Seicento 9 29-01-2009 18:04
(T) Drivers side (UK) dipped beam lamp replacement Ffoxy Stilo 0 18-02-2008 09:47
(T) Passenger side dipped beam keeps failing jcstanley Punto (Mk2/2b) 3 20-01-2008 15:09
(T) Changing Dipped Beam & Side lights...access near to none! lilman777 Bravo / Brava 6 11-02-2005 23:52
