Thread Tools
Old 04-01-2017   #1
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Uprated rear springs?
I know my arse of my cars getting saggy, age mikeage and a heavy hammering of speed bumps too much throughout the day, its getting tired
So wanna get new shocks, but im towing with a full boot im sat darn low, very low
So yes new spring woud help but was wondering if there was better springs out there?
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 05-01-2017   #2
Burkina Faso (Upper Volta)
Re: Uprated rear springs?
new springs would ideally be oe spec so should be good for 4 people a tank of fuel and a trailer
dont get unknown low dola untirnit ones
or lower dolla shockers
remember springs support
shockers dampen the bouncy bits
s and b is offline Reply With Quote Quote
Old 05-01-2017   #3
Quote Originally Posted by s and b View Post
Yea i redid the fronts about 2 years ago after just 1 spring snapped....
I like lemfoder springs nice quality and price
And shocks i look kyb as a rule
Will check out shop4parts etc
I think original is only way forward... may have to get some rummber spring assistors
Ziggy
Meet Bumble-Bee
Old 05-01-2017   #4
@s and b
What about the 1.4
There different to the 8v, by product code according to shop4parts...
Wonder with more power it needs thicker rear to accomodate the rear arse
Ziggy
Meet Bumble-Bee
Old 09-11-2019   #5
I didn't want to make a new thread for this so I will just ask here.
The rear springs on my sporting are showing the common sag and with people sat in the rear the back end is pretty much on the floor- no scraping yet though thankfully.
I want to ask- are the rear springs for the 1.4 sporting the same as the normal 1.2s or are they shorter/thicker?
According to eurocarparts they are the same product number but I don't really trust them
jason6168 is offline Reply With Quote Quote
Old 09-11-2019   #6
Croatia
Why don't you get eibach pro kit? I think it's -35 all around and it's one of the best lowering springs for the Punto on market
AnteLo is offline Reply With Quote Quote
Old 09-11-2019   #7
Croatia
I'm an idiot, I just read your post again. Doesn't the HGT and 1.9 JTD have stiffer springs in the back (and HGT having them lower as well)? What about Punto Van springs?
Old 4 Weeks Ago   #8
I don't know about the HGT or the JTDs but surely the Punto van springs have to be longer to deal with the payloads- probably too extreme for my case
I just want to know if anyone knows or has fitted 'normal' springs to the rear of a sporting.
The rear end sag when any load is put in the rear seats or in the boot is just going to get worse over time - I had to adjust my headlights to level 3 just to avoid blinding people the other night.
I just want the normal ride height back to deal with the terrible state of the roads, any thoughts?
Old 4 Weeks Ago   #9
If the old springs are getting weak it’s going to sit lower with the back of the car full.
Better to fit the correct springs they will immediate improve the problems you’re having, it will still sit low at the back when full anyway that’s a normal process for the car, as long as it’s not scraping it’s fine. The whole reason you have a headlight adjustment on the car is because this is a normal trait of the punto.
New springs are surprisingly cheap.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 4 Weeks Ago   #10
Quote Originally Posted by AndyRKett View Post
If the old springs are getting weak itís going to sit lower with the back of the car full.
Better to fit the correct springs they will immediate improve the problems youíre having, it will still sit low at the back when full anyway thatís a normal process for the car, as long as itís not scraping itís fine. The whole reason you have a headlight adjustment on the car is because this is a normal trait of the punto.
Do you know if the normal 1.2 uses the same springs as the sporting? Eurocar parts says they are the same part number
Old 4 Weeks Ago   #11
Quote Originally Posted by jason6168 View Post
Quite likely, dare say even the diesels use the same rear springs. If youíre not 100% with what ECP have said try GSF or one of the many other parts suppliers
Old 3 Weeks Ago   #12
Ive had a look at other sites, they all seem to say all rear springs are the same.
Il probably grab some new ones off ebay as they are cheaper
Old 3 Weeks Ago   #13
I had mine from S4p, they where About 6 years old when I replaced them, mine is the 1.6 mjet, these springs are standard ride height, but are stiff, not saying uncomfortable but I donít see them sagging before we become carbon neutral in about 2040.
Moimo is offline Reply With Quote Quote
Thread Tools
(G) uprated springs, no lowering Metalguru3 Cinquecento / Seicento 12 21-10-2016 12:37
(T) Uprated front springs? al18 Ducato 2 05-03-2016 23:39
(T) Uprated springs for 2008 X250 Deefordog Ducato 1 13-05-2014 15:16
(T) uprated/double valve springs Brooky Cinquecento / Seicento 49 31-08-2009 16:13
