Hello all,
First of all I'd like to say a huge thanks to people who have posted on the dreaded ECU/coil issue - I've been reading the posts and they've helped a lot.
I have a 2006 Punto Active 8V, 1.2 that has been intermittently running on 2 cylinders. The engine light sometimes turns off but then soon comes back on again and soon after that the car is running on 2 cylinders again.
I've followed the checks from the 'Punto coil-ECU checks' thread and identified which coil isn't firing. The test light shows the steady flickering so the ECU is sending the negative trigger/pulse.
So what should the next step be? Considering it has been an intermittent problem does this suggest that it's NOT the coil? Should I replace the spark plugs/coil pack/leads at this point? Are there any other things I should check first?
Thanks in advance for any help - I'm new to this so need it spelling out!
