Silent Chris
Hi. I'm having some problems with my 1.2 8v 2001 Punto (85,000 miles). About a week ago I was driving and suddenly the car started vibrating and I lost power so I pulled into a side street and stopped the car. The engine would still start up and run but, looking under the bonnet it was shaking around a lot.
I suspected a misfire. A compression test (dry) gave these results:
Cylinder 1 (timing belt end): 0
Cylinder 2: 0
Cylinder 3: 140
Cylinder 4: 180
So there's no pressure at all on cylinders 1+2. It continues to start up ok but obviously runs very rough (car stationary). Strangely I'm not getting any error codes or warning lights.
Would this be a blown head gasket, or a problem with the valves? I'm guessing head gasket as it would be odd for the valves to go in two cylinders wouldn't it?
Bit of background, about 2 weeks previous the engine overheated, went right to maximum on the dial and I stopped the car as soon as I noticed. I changed the thermostat and it was running great afterwards with the temperature gauge in the centre. I must have done about 400 miles after that and before the latest breakdown.
It would be great to have your thoughts. Are there any more checks I should do or is it definitely HG?
Cylinder 2: 0
Cylinder 3: 140
Cylinder 4: 180
