Thread Tools
Old 20-07-2015   #1
Head gasket replacement, Head bolts stuck
So I've been working on my car and it needed a new head gasket, low compression on 2&3 cylinder, emulsion in the oil e.t.c, Now i took the head extension off and I'm stuck on the head bolts. I've ruined a couple of the head bolts already they're so tight.. I have tried a blow torch but i never wanted to warp the head anymore, Is there any way of taking them out, Drilling? , I'm willing to do anything.
timmyyo198 is offline Reply With Quote Quote
Old 20-07-2015   #2
Brendan W has donated!
Ireland
Re: Head gasket replacement, Head bolts stuck
Are you using a twelve or six point socket. The six grips much better and the twelve if worn or not of the best quality will slip.
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Old 20-07-2015   #3
Hi, I'm using the six one, Ribed M8 right?
Old 21-07-2015   #4
Which engine? Assuming it's a 16v since you're talking about ribe bolts?
Straughany is offline Reply With Quote Quote
Old 21-07-2015   #5
If that's the case, try and hammer a spline bit in to it. Done it many times before, just got to be lucky and kiss your ratchet before you give it some pain
Old 21-07-2015   #6
judderbar has donated!
Finland
Quote Originally Posted by timmyyo198 View Post
The smaller M8 Ribe is needed on the head extension which you have written you have removed.
From checking this board, The much larger M9 Ribe is needed for the head bolts.
judderbar is offline Reply With Quote Quote
Old 22-07-2015   #7
grapeman has donated!
Cooking cookies Champion
Yeah m8 for head extension and m9 for head
grapeman is offline Reply With Quote Quote
Old 18-01-2016   #8
flisko has donated!
1.2 16v
air gun cant do ****, managed to do this on pic below with pipe extension, only 2 bolts are loose...
flisko is offline Reply With Quote Quote
Old 19-01-2016   #9
Finland
Quote Originally Posted by flisko View Post
1.2 16v
The splines of that drive look a bit thin to be a ribe drive.
My ribe looks like this
I think you have a torq drive there or something like it. The splines should be totally square.
Old 19-01-2016   #10
flisko has donated!
its not a torque drive, it came in a set, cheap one tho, have to buy proper one
Thread Tools
(T) head gasket replacement steve y 124 Spider (Classic) 0 09-01-2015 21:18
(T) Head gasket replacement tmccar Punto (Mk2/2b) 4 22-02-2014 21:07
(T) Head Gasket replacement... Jimbo89 Punto (Mk2/2b) 56 30-10-2011 18:30
Head Gasket Replacement Steve FIAT Boo Archives 0 20-12-2009 17:41
(T) Head Gasket Replacement LostThePlot Punto (Mk2/2b) 6 26-08-2008 18:47
