Hi, I have a fiat punto 2003 dynamic. I have a few problems if anyone could help me out:
1. When I press the clutch down and bring it back up it feels a bit sticky or rough near the biting point. I'm not sure if this is normal or if it can be easily fixed with a simple greasing on the clutch? Just to explain better when putting the clutch down near the biting point I can feel a little sticky sort of thing like its scraping against something (im not sure) and when I bring it back up it does this as well, has a little tough spot. Its not a easy up down action.
2. When the power is turned off and the key out my electric windows still work, is this bad and will it effect the car?
3. When putting in fuel it seems to stop every few seconds when put in full way, as I take the fuel pump thing out a little it works fine but im not sure if this is correct or efficient and also with this My fuel seems to run out really quickly like I fill up £30 and its only been like 1 day and its gone down 1/4
Please help with any of these if you can, much appreciated.
