Thread Tools
Old 10-08-2014   #1
PAS snag and erratic running
I'm new on here, having joined to help me keep my daughter's 2001 1.2 Punto up together.
The car has 70,000 miles and is largely fine. However it has developed an intermittent PAS snag - it's fine sometimes, not others. The battery checks out ok and the alternator is charging - though the latter does shriek periodically. I will probably change the alternator next job.
It also runs erratically at idle speed - all by itself the idle speed increases to about 1,500 RPM (no tacho so guessing) then drops down again, then up again and so it continues.
I don't expect the PAS and erratic idling to be linked - unless any of you experienced guys on here can say otherwise. Any help, suggestions, pointers etc gratefully received.
Thanks and regards
Andy H
bimble7116 is offline Reply With Quote Quote
Old 10-08-2014   #2
flisko has donated!
Re: PAS snag and erratic running
flisko is offline Reply With Quote Quote
Old 10-08-2014   #3
Trader Rating: 5
fingers99 has donated!
Unlikely to be linked. Hunting idle is often a dirty Idle Air Control. It's in the throttle body -- sometimes it can be removed and cleaned, else remove and clean the whole throttle body with carb cleaner.
For the alternator, you should get 12.6v from a good battery, fully charged, engine off, something in the order of 14.4v from the alternator (engine running) measured across the battery terminals.
If the squeak is from the belt, just replace the belt. If it's from the alternator, check it out -- it'll require at least new bearings.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 10-08-2014   #4
Burkina Faso (Upper Volta)
as said
belt needs changing
throttle body needs removing and tipping up and cleaning of idle control valve
then test with fiat ecuscan under actuations
once seen to clearly move in and out twice replace on manifold taking care to replace o ring in position
or change throttle body for known good one (warning they stick once put on shelves of sheds garages or scrapyard sales areas so one from a car not just scrapped yesterday may have a propensity to be no better)
s and b is offline Reply With Quote Quote
Old 11-08-2014   #5
Thank you fellas.
Flisko - couldn't get that link you sent me to open...? IT frustrates the ass off me sometimes.
Used a basic OBD reader on the car - no stored fault codes, which surprised me somewhat. Whipping the alternator off it later to check it and the belt - although the belt looks pretty fresh.
With the PAS - reading the many threads on here, changing the whole column seems to be the most common approach. Is there any intel on this, compatibility issues etc - any guidance/tips gratefully received.
Best regards
Andy H
Old 11-08-2014   #6
Brendan W has donated!
Ireland
Until the belt screech is sorted I wouldn't be thinking about replacement columns. The most frequent p/s glitch is undervoltage especially if it mainly happens when parking or unparking.
After that it can be fixed by replacing the onboard relays or the motor itself depending on the age of the car. Used columns are a risk but there are a number of companys repairing them for approx 160.
Likes s and b liked this post
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Old 13-08-2014   #7
flisko has donated!
Quote Originally Posted by bimble7116 View Post
Thank you fellas.
Best regards
Andy H
i wrote erratic running in search
https://www.fiatforum.com/search.php?f=34
Thread Tools
(G) Brava erratic running windrush Bravo / Brava 3 17-06-2009 12:59
(T) PAS packed its bags... (yet another PAS thread) Xen Punto (Mk2/2b) 7 13-06-2007 13:42
(T) Fast tickover & erratic slow running KeithT Punto (Mk2/2b) 1 09-04-2007 12:08
(T) mk2 punto 1.2 8v rough running/erratic revs smithpedro4 Punto (Mk2/2b) 0 02-11-2006 22:05
