Technical Fitting towbar to punto
dc2014
Hi i am looking to fit a tow bar to my mrs 2002 punto elx 8v just mainly for a bike rack for my crosser and wondering if anyone on here has fitting one to a punto just for a general idea of how hard or ocward it is and does exhaust have to be moved out of the way ect. Thanks
Yeah i actually saw one on ebay item number 271099429882 was a really good price and looks like has everything needed ?? Guy does have a few bad feedback but so do most who sell quite a lot
tow bar fitting,
look in boot floor, you will see painted style protective tape.
press on it and it will reveal 2 oval holes per side,
this is where you drop in the special square lockers,
look in corner,drivers side rear, you will see gromit. (wheres wallace?)
anyhow this is where you feed up wiring from towbar into lights,
remove bumper,
lower exhaust back box, no need to remove, but support it, dont bother with rubber exhaust mount just undue 13mm bolt and lower bracket down this has two plastic locaters,
pics here may help.
Does that mean sporting punto and active sports cant have a towbar purly because of the bumper.....
Thats somewhat annoying....
ziggy
Yeah i seen that bumpers with foam inserts will need moding , i do not know if hers has foam inside the bumpet because i havent had it off hopefully not tho :)
