im Axle Specialists
Old 17-03-2014   #1
Headgasket Failure...Need CODE!
Hi All,
Right i've not long bought my first Punto
It is a 2000 1.2 8v with 80k on the clock and the other day the issues started.
I drive it twice a week to my place of work about 6 miles from where i live without any issues except for an spilt second misfire for the first time i accelerate and then it goes. How ever this week i was 4 miles in on a cold morning and the engine temp light came on (got basic speed/fuel gauge) and when i got to work it was hissing under the bonnet. I drove home that night and same thing happened again. When i stopped i found coolant to be on minimum, the water looks like its got copper/gold flakes in it and is brown. The oil filler cap is covered in gunk and the fan is constantly going flat out.
I had the same thing with a Cinq i once owned so am going for headgasket again...
I've gone on Ebay looking for a kit but there appears to be different engine types/codes (eg:176, Y10) How do i find out which mine is??
Any tips or things to watch out for when doing the H/G would be appreciated too.
Thanks guys and gals
Lewis McLeod is offline Reply With Quote Quote
Old 17-03-2014   #2
dave's Avatar
Trader Rating: 10
dave has donated!
Re: Headgasket Failure...Need CODE!
a mk2 is a 188 a mk1 is A 176. Y10 Is A Lancia (POSH PANDA)
Thanks Lewis McLeod thanked for this post
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 17-03-2014   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
A mk2 is 188 Chassis
You have the 1.2 8v You engine is something like A400.xxx
You need a bog standard 1.2 8v HG SET
Advice
Sump is supported via trolley jack with some wood on it
Dont Jack straight on sump
When refitting Engine mount - do so with the engine still supported
Use Good fitting sockets
Need Fresh Oil - Oil filter - Coolant
You may need an Oil flush and Coolant flush too, as there will now be crap in both systems
You will need to have the Head skimmed, regardless if its flat or not, you need it also to be clean
Take your time
Things you should put in
New Water pump and Cam-belt
New thermostat - but these can be skipped IF there is service history and or okay condition
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 18-03-2014   #4
Thanks you two. Great to get that information and has made pricing parts much easier, but i have since found that for what it would cost me in parts, i could spend buying a s/hand 16v engine with 50k from a punto that has been rear ended...what would you do??
Old 18-03-2014   #5
dave's Avatar
Trader Rating: 10
dave has donated!
repair your engine. the 16v will need loads of extra parts to run
Likes homeward liked this post
Old 18-03-2014   #6
Sticking a 16v into an 8v chassis doable yes
BUT
its the insurance issue, it'll cost more
Plus you need to upgrade to sporting brakes, tyres, suspension etc etc to make it suitable to use!
ziggy
Meet Bumble-Bee
Old 18-03-2014   #7
Busy rebuilding pand'a
oldhammer's Avatar
oldhammer has donated!
Quote Originally Posted by Lewis McLeod View Post
Buy a mot failer punto off gumtree etc,
and swap engine over.
or look on ebay you can pick good 8v lump up for around 100 notes or less.
oldhammer is offline Reply With Quote Quote
Old 18-03-2014   #8
dave's Avatar
Trader Rating: 10
dave has donated!
Quote Originally Posted by oldhammer View Post
but if you cant hear it running it could be worse than what you have
Likes oldhammer liked this post
Old 18-03-2014   #9
oldhammer's Avatar
Quote Originally Posted by dave View Post
yep that is true,
Old 18-03-2014   #10
Brendan W has donated!
Ireland
I agree with Dave. Doing a hg on an 8v you know is a lot less risky than an unknown mill.
Be realistic about what's going to be replaced. Check the stat and pump. Timing belt ?
As it has overheated you should skim and reusing the head bolts would be doubtful ( get a good 6 point 13mm socket btw).
I replaced ours 22k miles ago with just the gasket,coolant and oil/filter but I had caught it very early and it never overheated and I wasn't that pushed if I had to do it again and it was only going to be me stuck on the side of the road if it went pearshaped.
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Old 18-03-2014   #11
Mine never overheated
So I didnt do a skim
Did check for warping but seemed okay and it lived till it died due to compression failure
Ziggy
Meet Bumble-Bee
Old 24-03-2014   #12
In the process of doing my mrs the now when you remove head check for any corrosion a one day job has turned into a week with waitin for parts and gettin skimmed and so far stands just over 200quid but thats good for the amount of parts i am changing
dc2014 is offline Reply With Quote Quote
Old 24-03-2014   #13
Quote Originally Posted by dc2014 View Post
I would have thought it'd all could be done for about 100?
Depends how far into you go
Like me i did them cheap - ie reuse belt - stat - pump(not cause btw)
But if it overheated, you'd need all the new stuff which does go up in price
Ziggy
Meet Bumble-Bee
Old 24-03-2014   #14
Well i got head skimmed twice and stem seals done 50 then timing belt kit , hg set, bolts , thermostat ,waterpump, plugs,leads, oil and coolant i would say for just ova 200 quid thts brilliant well i thought anyway
Old 24-03-2014   #15
dave's Avatar
Trader Rating: 10
dave has donated!
1.2spi multi headgasket failure benjamin7 Tech Talk 1 27-05-2013 10:33
(T) T-Jet Headgasket Failure GymJunkie Grande Punto 34 20-07-2012 19:40
(T) Possible Headgasket Failure? peaster2k Punto (Mk2/2b) 1 12-02-2009 22:02
(T) headgasket failure lincoln10 Cinquecento / Seicento 6 05-01-2009 19:36
(G) Headgasket Failure - how to avoid? circolo Bravo / Brava 5 27-03-2008 16:34
