I have a punto Mk2b 1.2 8V, and when i start the car when engine is cold,
there is a loud noise that sounds like a belt is slipping, and it get louder
when i rev up the engine.
The noise sound like it's coming from the clutch/gear area.
The noise stay the same if it's in gear or not, or if the clutch pedal is pressed or not.
After 10-15 minutes of driving the noise is almost disappear.
The timing belt was replaced, and the auxiliary belt is also quite new.
Can it be the clutch bearing making that noise?
I recorded the noise and uploaded to youtube. (There is a slight wind noise in the recording)
http://www.youtube.com/watch?v=XsJUuTcny9w&feature=youtu.be
Thank you.
Thank you.
