D desi New member Joined Oct 22, 2013 Messages 4 Points 2 Oct 22, 2013 #1 just need to know where the crank angle sensor is located? will I have to jack the car up as I think it is under the engine?
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Oct 22, 2013 #2 Strange terminology. I think you mean the crank sensor, aka TDC sensor, aka rev sensor. It's at about 3 o clock to the alternator pulley (from which it picks up the signal) on the timing side of the engine.
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Oct 23, 2013 #3 im with fingers here look at these 3 images, you'll never see such a clean engine! https://www.fiatforum.com/punto-guides/123687-were-everythingis-1-2fire-engine-2000-onwards.html Ziggy
