Thread Tools
Old 02-11-2012   #1
atom0007 has donated!
Inner tie rod replacement
How difficult is it to replace the steering inner tie rods?
it seems that I will need an inner tie rod replacement tool to do this.
And I will need to get the tracking done afterwards?
What would be a reasonable garage cost for both sides inner & outer tie rod replacement + tracking?
atom0007 is offline Reply With Quote Quote
Old 02-11-2012   #2
Re: Inner tie rod replacement
Quote Originally Posted by atom0007 View Post
That wasn't a question, I know this will need done....
Too early for me
Old 03-11-2012   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
I think the word you are looking for for is Track Control Arm
From the steering rack - its a ball joint - Track control arm
At the wheel end you have the track Rod end
Removal is pretty good going tbh...
Cause the track rod is gonna be scrapped
Remove nut - leave it on tip - tap with a hammer to pop it
then undo the Acordion gaitor on the rack - pull it down the track control arm
Undo the BIG ball joint as most are simply screwed in
Reftting is reverse of removal
REMEMBER to THREAD LOCK THE NEW CONTROL ARM INTO PLACE
Give it a lick of paint as well to seal it
Wack new ball joint on - drive Carefully to the tracking place and get it done
A big spanner job
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 03-11-2012   #4
Just a quick note
when you good Track control arm - i got lower wishbones....
Yet thats what we asked the part dept when i did one on a vauxhall astra....
Which are mega prone to them wearing out
Ziggy
Meet Bumble-Bee
Old 03-11-2012   #5
Trader Rating: 5
fingers99 has donated!
I'm still not sure which part you mean.
Could be:
track rod end (TRE) -- the L shaped bit
steering arm (bit that fits between the TRE and the steering rack)
wishbone (bottom bit).
Assuming it's the TRE, best to use a ball joint splitter. I like this type rather than the bask it wiv a big ammer type, 'cos they're safer and give you much more control. They're also very cheap on eBay. Oil the thread before each use.
So, use the splitter to remove the TRE from the wishbone, support the hex nut on the arm with a spanner and -- assuming that the old TRE is to be scrapped -- whak the threaded end smartly with a hammer to free it. Remove, pop the new one on, get the tracking reset.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 03-11-2012   #6
thought it might cause confusion:
bit between steering rack and track rod ends.
Surely that means they're "track rods"
But I've seen them variously referred to as inner tie rods, steering arms, inner track rods, track rods,.....
I've already replaced the track rod ends and the wishbones a while ago
Old 03-11-2012   #7
Brendan W has donated!
Ireland
I call them the inner tie rods. You won't be needing a splitter for them but some of them need a thin open end spanner to unscrew the inner joint from the steering rack. There is a good indy round here who charges punters 50 to replace inner tie rods if they supply the parts and then he goes off to the tracking shop and gets his mates over there to sort that for him.
Brendan W is offline Reply With Quote Quote
Thread Tools
(T) Tie rod threads heraldsteve Stilo 8 06-10-2012 09:24
(T) doblo inner tie rod ?? ypvs350 Doblo 2 25-07-2009 01:02
(G) Does anybody have a tie rod ends alfa145 Punto (Mk2/2b) 0 07-08-2007 14:33
(G) Tie Rod replacement (Steering) Alan.D Panda (Classic) 0 09-11-2005 21:12
