bapadiboopy
- Sep 21, 2012
- 1
- 1
Hello all. New member and first time poster here. Hoping you can help me out with a problem I have with my 1.2 16v punto 02 reg.
The symptom is a ticking noise when the engine is warm that occurs when the clutch pedal is released at half way. In other words when the clutch pedal is on its way up at the biting point (regardless what gear is selected, even happens in neutral).
This ticking will increase/decrease with engine speed. No ticking can be heard when the engine is cold. The clutch and slave cylinder have very recently been replaced to no change.
Has anyone had a similar problem?
