A Azmondo Patron member Parked in the garage Joined Oct 21, 2003 Messages 62 Points 38 Location United Kingdom. May 15, 2005 #1 Does any body know how to put rear brake discs on a punto that has drums on the back.how much would this sort of thing cost if i did it my self + just had to buy the stuff. all your help greatly appreciated
1 16v cab New member Joined Nov 21, 2003 Messages 109 Points 28 Location South West May 15, 2005 #2 You need to have a rear disc conversion. It can be quite expensive. PuntoboyGT will be able to tell you as he had to do one on his conversion IIRC
Puntoboy Jaaaag man. Parked in the garage Joined May 13, 2005 Messages 1,208 Points 216 Location Northamptonville May 15, 2005 #3 not only mine, bout your car Cat, how could you forget you require, the brake line fron the rear beam to the calipers, the calipers, hubs, mounting plates, stone guards. thats minimum. on my car i replaced the entire rear beam, suspension and trailing arms. and Cat's car i just replaced the nessesary.
1 16v cab New member Joined Nov 21, 2003 Messages 109 Points 28 Location South West May 15, 2005 #4 LOL, im a girl, i dunno what i had done. ;o)
