im Axle Specialists
Old 04-05-2005   #1
Red hot brake discs
I've just replaced the front brake discs on my Mk2 Punto 8V 1.2.
After fitting the new discs and putting the pads back in the callipers, I heard a bit of friction between the pads and the discs when I turned the wheel (before I lowered it to the ground).
I've been out in the car today for 10 mins, tested the brakes, they work fine but the discs were absolutely red hot when I got back.
Is it normal for the pads to rub slightly against the discs when driving?
I reckon this is causing them to get hot while I'm driving.
Cheers for ur help!!
nawtwrong is offline Reply With Quote Quote
Old 04-05-2005   #2
Re: Red hot brake discs
Your disks will always get hot - You can't stop that. It's part of the way they work. Your disk brakes work using friction, a by-product of friction is heat.
AFAIK, the pads and disks always rub together very slightly.
Mk2.5 Punto Sporting in Broom Yellow!
With problems...
alexb is offline Reply With Quote Quote
Old 04-05-2005   #3
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: 1
JonnyBoy has donated!
There's normally a little contact between pad and disc with the brakes off, this isn't enough to generate any noticeable heat though.
A lot of heat is generated when you actually brake though, and it takes the discs a while to cool down. Sounds like your brakes are fine to me.
Past: '91 Uno 45 Formula; '94 Punto 55SX; '58 Bravo 1.9 Multijet (150BHP) Dynamic, with extra toys
Present: Several, but nowt Italian...
JonnyBoy is offline Reply With Quote Quote
Old 04-05-2005   #4
Thanks, thats ok then. Just wanted to make sure for when a txi driver pulls out in front of me!
Cheers!!
Old 04-05-2005   #5
Location: Dundalk, South of the border accross the water
Ireland
Em, but red hot after normal driving?
Even on track days I didn't notice my brakes to glowing red after a run
Gearóid
http://homepage.eircom.net/~volkswagen/g40ontrack.jpg
92 G40, Stage 4 charger, K&N, de-restricted air box, cat back stainless system,
koni's & eibachs, front lower strut brace, vdo boost gauge, dealer fit electric windows.
97 Marea weekend 1.6 16v
gsbellew is offline Reply With Quote Quote
Old 04-05-2005   #6
Banned
darkcircuitUK's Avatar
darkcircuitUK has donated!
Think its just a figure of speech
darkcircuitUK is offline Reply With Quote Quote
Old 04-05-2005   #7
arc
this is where i stand
arc has donated!
Quote Originally Posted by gsbellew
drive harder
the pic is from a 1l corsa, but we did the same with a 1.2 8v punto
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 04-05-2005   #8
Mr Pedantic
hmallett's Avatar
Trader Rating: 1
hmallett has donated!
You say you tested the brakes for 10 minutes, so obviously they'll get hot then, but how long did you drive for without heavy braking? I think it can take quite a while for the disks to cool back down, especially if you're not moving. The only times I've had red-hot disks are when:
The rear brake was binding slightly. This squealed a lot too.
A session of "spirited" driving down some back lanes. I actually got the pads smoking quite heavily
Try again, and drive for a decent period with as little braking as possible, possibly even doing the final stop on the handbrake. Then see how how they are.
H
Quote Originally Posted by 306maxi View Post
I love the Panda forum.... you guys are so much more chilled out than the 500 guys
hmallett is offline Reply With Quote Quote
Old 05-05-2005   #9
Ireland
Quote Originally Posted by arc
drive harder
Ahhh right, I suppose the solid disc wouldn't help in comparison to my vented ones, and seeing as I can barely see the brakes I suppose I don't know what could be going on behind the wheels really, still though, for normal driving the brakes should not glowing.
Gearóid
Old 05-05-2005   #10
arc
arc has donated!
you know, i don't know if puntos have vented discs or not - but yeah, you are right normal driving they shouldnt be glowing!
(T) Brake discs braden Stilo 11 15-04-2005 09:45
(T) Fitting brake discs!! Southey Cinquecento / Seicento 6 17-11-2004 16:03
(T) Brake discs. anthemmaster Bravo / Brava 7 28-10-2004 13:04
(G) Front Brake Discs mrhatch Ulysse 18 31-08-2004 13:03
(T) changing front brake discs on X plate punto 1.2 naz Punto (Mk2/2b) 1 20-11-2003 03:45
