Silent Chris
Hello all,
So, my battery is draining with the car switched off (2001 Mk2 1.2 8v). It struggles to start after a few hours and is pretty dead if left for a day. I got my trusty multimeter out and found that it was draining 650mA with everything off which I think is quite a lot. With the meter connected I started pulling fuses out one by one and one fuse F18 caused the current to fall to almost zero so this must be the culprit. The fuse is for Engine Management Control Unit but I'm not sure where to go from here.
I read the other threads on batteries draining but couldn't get to the bottom of this. I'm pretty sure I don't have a problem with the battery or alternator as I measured 12.5v across the battery with engine off and 14v with engine on. If I disconnect the battery for a few days it holds its charge. I have the original head unit and it's not the boot light (usual suspects).
This problem seemed to start after I got the head gasket changed at a garage. Does anyone have any suggestions as to what I should do next to diagnose/fix this problem.
Chris.
Chris.
