they are perfect for out the bottom ... with good axle stands ,,,, and a tall trolley jack piece of thick wood ... couple of mates at end stages ...
undo loom at fuse box and battery leads two plugs i think follow loom from engine into your under bonnet fuse box ( very easy ) just un-plug ..... take battery out and carrier off ( the tray ) x3 13mm bolts .....
x2 10mm bolts and sping clip ....... air box off
disconect exhaust at front to middle section then when on floor it stands up on its own ..( if you leave it connected to head ...this helps on floor ) x2 12mm or 13mm if had new bolts ... take time because these snap dead easy .. wd 40 ...
tigh it up out of way as it will dingle dangle .... (middle section ...
before putting on floor while in car disconect all the under neath gearbox bolts ... 10mm for **** shield .. 15mm 17mm 18mm 19mm may need two spanners of each
easier than when its on floor ( dirt shield off ... ..... drop hubs and pull shafts out and leave the gearbox drive shaft cups in box ..(doing it this way you have no oil loss out of gearbox ) ( the inner cv boot will pop off shaft when you remove the boot clips ..
stretch two rubber gloves over inner cv;s on the end of shafts ....... less mess ...
water hoses .... rad top and bottom hose .... and matrix hoses x2
throttle cable comes off by turning butterfly and unhook it ...
fuel pipe .... special pliers ....
disconect gear linkage by putting 15 spanner under the x2 ball sockets and flick them off .... then you will see x3 13mm bolts that hold the linkage bracket on gear box /..... then tie it up to brake pipes on bulk head ... cable tighs ... and disconect clutch slave cylinder on top of gearbox x2 13mm bolts and swing this down near rad ... undo the gear box earth strap .. you will see it when this is off ...
disconect the reverse switch wires on front of gearbox . ...
speedo wires on rear of gearbox ... ( some dont have these ) just a blank ...
vacum pipe off at maniold by squeeze in the clip with fingers while pushing inwards
when you undo the rear steady bar the engine and gearbox will swing on the gearbox mount and the engine mount ..... this is safe ....
place jack under sump with good piece of wood and take the weight checking that i have not missed nothing .....
undo the 19mm top gear box mount bolt .... but only with jack in place ....
then undo the x3 or x4 engine mount nuts 15 mm ... near top timing cover ..
take your 17mm socket and remove the x3 inner wing mount nuts ...........
get a friend to say grace ... no hold the engne and lift off mount and lower jack ....checking at all times there is nothing still conected .....
doing it this way the starter ... loom ....... every thing drops as a full unit
when on floor disconect starter bolt x3 13mm two at rear of starter and one on top of box ...... and top and side gearbox bolts
x1 nut 18mm or 19mm next to starter at rear and the box slides off ....
x2 18mm top bolts .......
hope this helps ...
i do two of these a week .... but on a ramp ... takes me two hours ... taking time ..
when lowering jack slowly move the jack slightly forward to clear exhaust at rear when lowering ........
swap everything from old engine to new one ,,,,,, and reverse the out distructions ..
remember you need an engines worth of height with your front bumper still on to slide it from under neath ......
no body panels removed ..... as you have a front cross meber (welded in ... )
leave bonnet on ... nothing off panel wise ///
GOOD LUCK MUCKER ...... :slayer::slayer::slayer::slayer::slayer::slayer::slayer::slayer:
