AdamMaguire
I've been having a bit of trouble with my Punto (2001, Mk2 1.2l etc) lately and a friend reckons it's a clutch issue - it definitely feels like it's something along those lines (if not the gears themselves).
Basically all of the 'umph' of the car seems to have gone in the last while. Starting off at a set of lights you can feel the first gear struggling to get up to speed and the car can sometimes have a hard time getting speed up in general.
If it's on a hill that's even more true.
On top of that (a connected issue, I imagine) the revs sometimes spike while driving, usually when I'm trying to get the speed up (though I'm not flooring the accelerator - just gently adding pressure as you would).
The only way I can describe this is it's as if I've suddenly taken the car out of gear. It might go up for a second with no extra power actually going into the forward motion of the car and then it drops off again; or else I have to ease off on the accelerator and try again.
So does this sound like clutch trouble? From what I gather it's a fairly expensive problem to fix.
I've to leave it in later this week to do a job on the CV Joint so I'll ask the mechanic to give it a look... I'm hoping it's something minor and easy to fix!
Thanks.
Thanks.
