First off, fantastic forum, proper impressed with attention to detail! Any way to the point.
My old man has just got hold of a mk 2 punto with the 1.2 8v engine. Last night he was driving along and lost all power. Had a look this morning and by joe its running very rough. struggles to start and when it does its seriously lumpy as if running on a couple of cylinders. If you rev it slightly it splutters and dies but if you kinda of pump the pedal a few times and get it running it proper chugs.
So, i replaced the plugs, leads and that didnt work. Got hold of a brand new coil and tested it on both sides (didnt spot the easy way on hear until afterwards) and again, didnt work, still the same running issues with no improvement whatsoever.
After a few calls it was suggested a injector failure is the most likely cause. This is where my skills get a wee bit thin.
How, if at all, can i test the injectors????
Any other ideas are more than welcome. Ive seen the thread about redX, could it really be that simple???
Many thanks for reading and many MANY thanks in advance for and help you guys give!!!!
Dave
Dave
