Hi there, I recently bought a 54 reg 8v Active. It had been standing for a few weeks before I got it.
For the first few days the power steering (EPS) cut out once a day, usually with lights and fan on and while using full lock. Once I got the warning light without the steering cutting out. This prompted me to buy the FiatECUscan software and licence and an ELM327 interface.
I ran the scan and got errors 1005 and 1006, torque and position sensors, which indicate a replacement column is needed. I have no problem with this as the car was suspisciously cheap, so I suspected something like this. £160 for a recon unit from several respected sources, and a day or less to change it is ok with me.
Having read cases on this forum though, I now have some doubts. I have since driven 600 odd miles, mainly motorway, and the problem hasn't recurred. I don't want to go to all the trouble of changing the column only for the fault to recurr.
Sorry for the long build-up, my actual question is this - has anyone had a torque/position sensor error which has been solved by a new battery or alternator? I could test them both this week at work, but they may turn out to be ok as they are now back in use.
Has anyone experienced getting the torque/ position sensor fault code which wasn't the torque sensor?
Thanks, Darren.
Thanks, Darren.
