General Strange problem with indicator
philtorrens
Northern Ireland
Hi folks I have a strange problem with my front left indicator on my Punto at the moment where it doesn't come on and hence all other indicator bulbs flash at twice the speed. Swap tested the bulb with the drivers side and same problem so I took it to a guy who changed the bulb holder and 'repaired the wiring' in his words. Worked fine for a few days and started again today but now it seems intermittent :confused: Pulled in to a shop, kept the indicator going and the front left wasn't coming on but when I came back out it was working fine again. Is there anything I can do at this point or do I need to take it back to him again?
Sounds like a loose connection or dodgy wiring to me. You could take a look if you know what he did exactly, else I'd take it back and make him fix it.
Thanks for the reply. First thing im going to do is check he did actually change the bulb holder then I may need to take it back to him. Can only think it must be a dodgy wire as it's an old car now.
