NeilNorton
- Mar 20, 2011
- 8
- 1
My daughter's Punto stopped at a set of traffic lights. The AA said that the belt has gone. After googling to this forum thought I'd give it a go after 30 years away from car DIY (Fords)
The belt is intact with no signs of missing teeth or tearing and the tensioner seems to be ok (90 degree twist method). Can they slip?
I thought it would be easy to check the timing but the modern Haynes manual misses out loads of steps for this Fiat novice.
I've been trying to get the auxiliary belts and pulleys off but noticed posts about marks through bell housing. Looking from the battery it looks like 3 or 4 triangular teeth on the housing (which one do I line up with?) Also I've seen grooves, holes and studs through the hole so which do I use? Can anyone provide a link to pictures etc
When I turned it over without the air filter box, petrol was spitting up from the injection unit. Is this normal or signs of an injector problem?
