Brought a mk1 60s as a sell on project.
The car had been sat for a year or so with no brake fluid in it. I have replaced the rear cylinders as they were solid and have bled the brakes. Now when the engine is off the brakes feel fine. When you start the engine the pedal moves about 3" (75cm for the younger ones) before any braking force applies.
Is it the master cylinder or could the vacuum unit need adjustment/replacement.
