Thread Tools
Old 19-12-2004   #1
Water Leak
Help!
I have a mark 2 W reg Punto and have been having to top up my coolant a lot recently. I even changed the water in the radiator (which was a very creamy colour) which made me think it was a head gasket.
Until this afternoon when I noticed a small drip of water that was coming off the oil filter. Looking closer the water is leaking from the pipe above the oil filter. This pipe comes out the radiator then goes into a Tee piece above the oil filter, this Tee piece then goes into a housing to which I assume contains the water pump. Where this pipe enters the housing is where the water is leaking from. Has anyone had any experiences of this?? Do I need a new pump, a new pipe or a new housing??
Any thoughts or help would be appreciated!
Cheers,
Martin
martin.butler is offline Reply With Quote Quote
Old 19-12-2004   #2
Re: Water Leak
hi fiat guru here
it sounds like it is going to need a new pipe and o ring
[FONT=Comic Sans MS]WE BLOODY LOVES IT SEE !!![/FONT][COLOR=Red]WE BLOODY LOVES IT SEE !!![/COLOR] :D :D :D
kinedders is offline Reply With Quote Quote
Old 20-02-2005   #3
Re: Water Leak
Hi all,
I have the same problem. The pipe moves and I there's a big leak. Could someone please indicate how to fix the pipe and/or o-ring? I mean, is it tricky, easy...???
Thanks very much in advance
Guillermo
Yorkensen is offline Reply With Quote Quote
Thread Tools
(T) water leak in passenger footwell blackpool_uk Punto (Mk2/2b) 9 15-12-2004 22:07
(T) 'Monster' Water Leak DeeDoubleYoo Cinquecento / Seicento 6 10-11-2004 00:56
(T) Radiator / Water Leak pyrrho Punto (Mk2/2b) 5 22-07-2004 22:52
(T) water leak jeppef Marea 2 09-04-2004 03:38
(T) Tipo water leak...in the cab gavnotts Tipo (Classic) 1 14-03-2003 08:10
