Old 14-12-2004   #1
wipers judder?!
I have a MK2 1.2 sporting and my wipers are acting very strange...
on mine i have 3 wiper settings first i can adjust with 4 extra speeds on a turning thing on end of wiper stick and the other 2 are your standard slow and fast. .....
on the first setting with the extra adjustable speeds the wipers go up fine then on way back down they kinda stick and judder slowly down anyone had same problem and how to fix this?
i thought was just the wipers sticking to windows but i lifted the arms up and it still does it then...but weird thing is the 2nd and 3rd wiper selections run fine?
hope you understood all that haha
nickphonics18 is offline Reply With Quote Quote
Old 14-12-2004   #2
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: wipers judder?!
It's a common problem that should have been fixed under warranty. Fiat used the a lubricant that solidifes causing the wipers to judder. They replace it with different lubricant and it solves the problem. Your dealer will be aware of it, so push them to fix it foc.
2015 Fiat Panda Pop
Steven is offline Reply With Quote Quote
Old 14-12-2004   #3
Re: wipers judder?!
ah right ok thanks....i bought it privately so will have to pay...any idea what it might cost?
Old 14-12-2004   #4
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: wipers judder?!
If you push then I doubt they'll charge you. It takes half an hour for them to sort it and most Mk2 Puntos have been done already with no charge. If you go in at least pretending to know what you're talking about you'll be fine.
Best bet is to ring a local dealer and speak to them.
2015 Fiat Panda Pop
Old 14-12-2004   #5
Re: wipers judder?!
hi fiat guru here,
They probably will charge you but not much at all, but if you want to try it we could tell you how,
Only need a philips screwdriver and a 25 torx.
[FONT=Comic Sans MS]WE BLOODY LOVES IT SEE !!![/FONT][COLOR=Red]WE BLOODY LOVES IT SEE !!![/COLOR] :D :D :D
kinedders is offline Reply With Quote Quote
Old 15-12-2004   #6
Ems
Cruising in the Fens!
Ems's Avatar
Ems has donated!
Re: wipers judder?!
Mine does it too, already changed the wiper blades as I thought they were the problem. I'll take it into the dealer then and smile sweetly
2001 Punto HGT
Ems is offline Reply With Quote Quote
Old 15-12-2004   #7
Re: wipers judder?!
thanks for the info ill see if i can take it into fiat at the weekend. ill let you no what happens
Old 15-12-2004   #8
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: wipers judder?!
Remember, don't pay them! Argue with them!
2015 Fiat Panda Pop
Old 15-12-2004   #9
Re: wipers judder?!
Found this step by step instruction to cure the wiper judder on an other web site, have a look and see if it helps
http://www.puntomk2.co.uk/
john1804 is offline Reply With Quote Quote
Old 15-12-2004   #10
Re: wipers judder?!
ohhh thank you very much where do i go from the site to find the step by step guide?
Old 15-12-2004   #11
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: wipers judder?!
Excellent! Not such a hard job either!
2015 Fiat Panda Pop
Old 15-12-2004   #12
Re: wipers judder?!
all you have to do is take the two screws out from the black plastic (driver side and middle) lift that up as much as you can, then put something there to hold up (block of wood), Take the plastic motor cover off ,
with the cover cut the end off where its a lng straight flap jst cut off to get it back in much easier. Un clip the switch.
take the 5 x 25mm torxs out, now the top part will come off. DONT LOOSE THE SEAL.
then you will see two copper contacts on the top half, clean them and push them up a bit more, then clean all the orange colour (sometimes white) grease off the motor, once clean put it all back togetha, (do not need to re-lubricate what you cleaned.
Old 16-12-2004   #13
Re: wipers judder?!
If you go to the web site as above and search for "wiper judder guide" it will find the post and a link to download the word doc wit instructions
Old 16-12-2004   #14
Re: wipers judder?!
ok ta...ill guess ill have ago myself
Old 16-12-2004   #15
Professional Know-It-All
MR.COATES's Avatar
MR.COATES has donated!
Re: wipers judder?!
Nick, I've got a guide for this.
__________________________________
Yellow Punto? A bit girly isn't it?
http://img9.exs.cx/img9/8633/fogs.gif
MR.COATES is offline Reply With Quote Quote
(T) Brava Intermittent Wipers not working zwyzyk Bravo / Brava 4 19-10-2004 14:33
(T) front wipers gone mad Bradford_HGT Bravo / Brava 1 26-07-2004 21:37
(T) windscreen wipers hibs72 Stilo 9 19-06-2004 17:07
(T) We want answers about the judder Joey Punto (Mk2/2b) 5 15-12-2003 21:06
(T) [cinqo] wipers Fiat Powerrr Cinquecento / Seicento 8 28-11-2003 22:10
