I recently changed the CAT on my 1249cc 2001(Y) fiat punto (5dr) after it cracked and sheared off at the lower weld. The rear rubber mount for the exhaust had split when i was on the motorway, so one expediant repair later im on my way, courtesy of some tie wraps. this however had the effect of putting alot of force back down the exhaus to the lower weld on the cat, snap. :-(
So, £170 quid or so later from my local motor factor, and i have a new exhaust to fit.
Those manifold bolts were a bugger to come off when i changed my head gasket last year, i should have replaced them then!
So, new manifold bolts and nuts, and new gasket and exhaust fitted, good to go, except now it sounds like its a VW camper van. It starts fine, but i seem to have lost a bit of power, and its hesitant to set off espicaially if on a gradient.
it sound like this:
now, it could be that it has always been running rough, but the combination of new cat and gasket has gotten rid of other noises to make this one more obvious, i dont know, but the drop in power makes me think not.
i'm looking into the lambda sensors as a cause just now, as per my other thread:
https://www.fiatforum.com/punto/206872-punto-mk2-lambda-sensor-resistance.html
Any thoughts would be appreciated.
it sound like this:
