FleX1337
Hey,
My battery has been draining recently. I have had to replace the original because it had drained too much which broke it.
Got a new one in and still keeps draining. It's rapidly too because overnight the battery will be dead the morning after.
I regonised a slight humming noise when sitting in the car. So decided to investigate. The humming noise dissappears after the battery is disconnected. So I decided to pull all the fuses and relays one at a time. When I pulled out a certain relay it stopped, and the battery didnt drain. The relay was also very hot so it has always been used.
I just need to know what the T09 Relay is for, and if I need to replace it.
