im Axle Specialists
Thread Tools
Old 07-03-2009   #1
Metallic rattling noise since timing belt change?
Strange one this.Replaced the timing belt in my 96 1.2 60sx Punto about 5 months ago.Since then when you start it you will hear a metallic rattling sound coming from the timing belt side of the engine.It doesn't happen all the time,which is strange,some days it won't do it at all?If i was to describe the sound it sounds like a small steel ball rattling about in a small steel box?Anyone any ideas?
robbocop is offline Reply With Quote Quote
Old 08-03-2009   #2
Re: Metallic rattling noise since timing belt change?
Quote Originally Posted by robbocop View Post
Yep, I can relate to this one. I would be interested to hear what you guys think!!! Please come back with some suggestions.
Robbocop have you checked for any oil or water leaks?
I had my cam changed a few weeks ago and been getting the same problem along with a water leak from the water pump and squealing noise on cold start, which has been well reported on other threads. You seem to be defo getting the same rattle like mine after the cam change.
kal1 is offline Reply With Quote Quote
Old 08-03-2009   #3
I actually replaced the water pump when i was doing the belt.Don't think there are any leaks either.It's just the fact that some days it won't make the noise at all confuses me?
Old 08-03-2009   #4
Hummm its a difficult one.
Come on guys, is there anyone with some suggestions plz?
Old 10-03-2009   #5
bump
Old 10-03-2009   #6
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Is the cam timing spot on? I saw a Post from dave the Mod on here the other day, these engines cant be done without use of the correct locking tools as the timing slips when the tensioner is adjusted if the proper kit isnt used. Only needs to be a tooth out. Check if the belt has gone slack and is catching the timing belt cover intermittently maybe?
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Thread Tools
(G) Rattling noise and timing belt sliping....HELP! Fry1330 Punto (Mk2/2b) 0 19-07-2008 18:28
(T) Timing belt Change saibeml Uno 4 30-05-2008 12:57
(G) Timing belt change Paul-C Punto (Mk2/2b) 2 31-01-2008 22:23
(T) Fiat Marea 1.6 16v rattling noise after cambelt change. KevB1964 Marea 3 11-03-2007 16:03
(G) Fiat Marea 1.6 16v rattling noise after cambelt change. KevB1964 Marea 1 11-03-2007 06:34
