Hi
Popped my new to me 04 1.3 multijet diesel Punto in to a nearby Fiat dealer for a look over. The car had been supplied and serviced by them, the last service being done 1K miles ago.
They've identified some problems which your comments on would be much appreciated.
The most serious is a weeping water pump, which I hope I can have fixed under warranty. If I can't, how difficult is this to repair? The car has only done 42K miles, is the pump a known issue, or am I unlucky?
The next most serious is that both rear shock absorber bushes have split. Don't think that this will be covered by warranty, so I will have to have them sorted myself. Is this a diy proposition? If so, is this covered in a Haynes manual - the only one available covers the petrol model only, can't see the diesel back end being very different somehow. Is this a serious fault - I can see that the water pump needs doing asap, what are the symptoms of split bushes? The car seems to drive OK, is this an MOT issue, do I have to fix this straight away?
Lastly, the front disks are corroded - the subject of a seperate post. I'll have a go at sorting this myself.
Not mentioned is a faulty heater fan speed 3 - this doesn't work, imagine this is a burnt out dropping resistor. My car has air con, is sorting this out any different from the non-air con version?
Thanks in advance
Thanks in advance
