Raducu
Member
Hello everybody,
mk2 8v active sport and I have a problem with the wipers stalk (remains stuck in the rear washer position). So I would like to take 'em off and give it a look, maybe I can fix it. I did a little bit of searching and the procedure is (correct me if I'm wrong):
1. disconnect batery and live it for 30-60 min
2. remove steering wheel panel (3 bolts behind)
3. remove airbag :chin:
4. remove steering wheel
5. remove stalks.
Is that ok?
But if I disconnect battery for an hour my built in CD player Blaupunkt High will still work? (I am not sure I have the code)
I would appreciate any guide, suggestion, hint, help, beer, or anything.
5. remove stalks.
Is that ok?
