Fault coming from 7 sensors, i done diagnostic las weak.... They recomend me clean all air hoses but i can see difference.....
ok, i gona order lambda as well!!!!!!!! Cheers
did you check the AFM? might aswell do one thing at a time and rule things out one by one..no point spending loads on bits you might not need
New Lambda sensor is in and still problem... what i should do now?? :bang:AFM is going well..... now lambda is my target
