![]() | #1 | ||
Posts: 482 Thanks: 8 Trader Rating: 0 ![]() | Starter motor problem hi, i have a 1.3 multijet punto on a 03 plate has anybody had a starter motor problem.The car has only done 23000 miles just wondering if it was a common fault on these engines as it seems to be a low mileage for this to occur.Is there anything i can do to cure it or do i need a new one Thanks shaun
![]() | #2 |
Posts: 4,781 Thanks: 101 Trader Rating: 0 ![]() | Re: Starter motor problem whats the problem?
__________________ ![]() |
![]() | #3 | ||
Sei Sporting abarth Join Date: Mar 2007 Location: Kent
Posts: 1,168 Thanks: 22 Trader Rating: 0 ![]() | ![]() Does the motor sometimes work ? & does it usually fail after a fast run?
![]() | #4 | ||
Posts: 482 Thanks: 8 Trader Rating: 0 ![]() | Re: Starter motor problem Sorry, when i try to start i get a clunk and then nothing.if i try it when it is left over night it will start first time but when the engine is warm it can take up to 20 times before it fires up
![]() | #5 | ||
Posts: 482 Thanks: 8 Trader Rating: 0 ![]() | Re: Starter motor problem hi FIREsporting, yes it does much worse after a run
![]() | #6 |
Posts: 4,781 Thanks: 101 Trader Rating: 0 ![]() | Re: Starter motor problem i'd say starter solinoid sticking try removing the starter and cleaning and grease the shaft then refit and try it out, if this doesn't work you probably need a new starter, get one from motor factors much cheaper than fiat
![]() | #7 | ||
Posts: 482 Thanks: 8 Trader Rating: 0 ![]() | Re: Starter motor problem Thanks toad101 looks like a new one
![]() | #8 | ||
Posts: 1,168 Thanks: 22 Trader Rating: 0 ![]() | ![]() Hiya shaun, May by Replace solenoid switch or id get a reconditioned Starting motor it's easy to do. ![]()
![]() | J.R Racing | Cinquecento / Seicento | 23 | 05-02-2008 00:35 |
![]() | jimnewson | Bravo / Brava | 13 | 06-01-2008 19:25 |
![]() | bluejohn125 | Tipo (Classic) | 0 | 21-03-2007 20:36 |
![]() | adadof2 | Marea | 18 | 09-01-2006 07:36 |
![]() | DaveHall | Panda (Classic) | 7 | 05-11-2004 20:57 |
