My 03 Punto diesel came to grief yesterday whilst my daughter was using it. Recovery man's diagnosis was broken timing belt. Car has done 76000 miles.
Would like to know
1) Is this is a 'safe engine' in respect of timing belt failure. As far as I can see it has 8 valves which for other engines appears to be the key issue
2) If the answer to the above positive is the belt replacement a straightforward task for a competent amatuer? I have changed belts on Ford Escorts/Orions in my past but this engine looks a bit more crammed in
3) If the answer to 1 above is bad news what is the best solution -try to get broken down and repaired or just go for recon engine?
Would like to know
