![]() | #1 | ||
Posts: 14,690 Thanks: 370 Trader Rating: 1 ![]() | Gearbox Oil Fill plug hi, Would just like to know what the gear box oil filter plug should be and look like on a >2003 Punto mk2b Sporting 1.4 16v. The reason I ask Is that the one it seems to be on my car is a loose flimsy plastic cap which doesn't fill the hole properly and could let all sorts of s**te get into the box. Also what grade oil should I use in the gear box I need to refill it now as Ive got a slow leak from the near side driveshaft oil seal.
![]() | #2 | ||
Posts: 2,861 Thanks: 330 Trader Rating: 0 ![]() | Re: Gearbox Oil Fill plug The "flimsy plastic" on the top is a breather vent cover. The level (filling) plug is a 12mm allen plug mounted in the side of the casing about halfway up (at the front- look up from underneath the vehicle). Just fill it up until the oil spills out of the hole. Official stuff is 75w synthetic. ![]()
![]() | #3 | ||
Posts: 14,690 Thanks: 370 Trader Rating: 1 ![]() | Re: Gearbox Oil Fill plug The "flimsy plastic" on the top is a breather vent cover. The level (filling) plug is a 12mm allen plug mounted in the side of the casing about halfway up (at the front- look up from underneath the vehicle). Just fill it up until the oil spills out of the hole. Official stuff is 75w synthetic. ![]() ![]()
![]() | Jaff_Fox | Panda (Classic) | 9 | 30-04-2013 22:00 |
![]() | Midlander | Bravo / Brava | 14 | 28-05-2007 00:43 |
![]() | cycento | Cinquecento / Seicento | 16 | 08-01-2006 17:55 |
![]() | Blondeinapunto | Punto (Mk2/2b) | 4 | 04-07-2005 18:19 |
![]() | vfourracer | Tipo (Classic) | 7 | 01-07-2005 13:59 |
